Massive slow down in service
h9999
http://www.speedtest.net/result/3991580165.png
Anyone else had really slow fibre lately?
Usually get around 27mbps - getting 4.11mbps!!
Fixes: 235
Re: Massive slow down in service
Hi there.
Testing isn't showing any issues with your line. Are you running these tests over a wired or wireless connection?
 Matthew Wheeler
h9999
Wireless, but sitting right by the router with the strongest signal I could have.
I have rebooted the router and am now getting 18mbps, which is still around 10mbps than usual.
I am trying to watch iplayer and although I can watch the adverts perfectly the actual film will not play.. The sound keeps going off and the picture is lagging.  Now the whole screen has gone blank.
Very concerned as we have just renewed with you and have had very few problems in the last 18 months until now.
Fixes: 167
What speeds do you see on a wired connection? I'm interested if that's the cause.
 Chris Parr
 Plusnet Staff
