Massive reduction in download speed today can someone please reset my profile
FIXED- Subscribe to RSS Feed
- Massive reduction in download speed today can some...
14-04-2017 11:46 PM
I'm away from home at the moment but downloading remotely by via my nas. Normally i download at 72 meg speeds. Currently hitting less than 1!
Nothing has changed at my end and this happened last summer and needed my profile to be reset by plusnet. Please can you check and do this again for me.
Mat
Fixed! Go to the fix.
Re: Massive reduction in download speed today can someone please reset my profile
15-04-2017 12:39 PM
You can check your lines BT profile at the following link, this should give a indication of your present downstream sync speed. Just need to enter your home phone number.
https://windows.mouselike.org/be/index.asp?DoAction=BrasChecker
Your Plusnet IP profile can be found in PN's Members Centre,
15-04-2017 1:17 PM
The current Downstream BRAS rate is: 77.34 Mbps
The current Upstream BRAS rate is: 20 Mbps
So can anyone tell me why my downloads are like the old dial up speed on a 56k modem?
-Mat
17-04-2017 5:35 PM
Well, just got home and sure enough, a reboot of the modem fixed the problem. Must make sure that's remotely accessible in future.
-Mat
