Manangin up stream rates
bastonian
Hi
I need to change my router. I have a VOIP phone and need to control
the up rate for this device so its not competing with my laptop. When
my laptop is syncing files with my file sever located on the web I get
voice distortion, not at my end but at the end of my friends.  Can you suggest a router that works well with
plus net service and where I can control the band width(both ways) on certain IP addresses
Many thanks
Jason
Fixes: 4
Re: Manangin up stream rates
Nice list here, QOS is what you are looking for to sort that problem out. you don't mention what speed you have, I'm guessing 40/2 ?
bastonian
Thanks 55Mbps down and 15Mbps
