Major issue, should have been activated yesterday, no signal at all..
- Re: Major issue, should have been activated yester...
10-02-2017 3:09 PM
Hi there, I have already raised a fault and contacted your representatives although nobody could really give me any details or a timeframe... I was transfering from Talk Talk as their service and speeds were nightmarish and I have heard a lot of good stuff about you.
The activation date was the 9th of Feb, Talk Talk line went dead yesterday so I plugged in the Plus.net router and my landline phone. There was no signal when I picked the phone up and router could not connect to the broadband neither.
I have contacted you guys and raised a ticket, I have been told that you ran test on the line and that everything seems fine, then next person told me that there is definitely an issue with the line. Now I don't really know where I am, I've been told that the issue is "being resolved" but nobody can tell me how long it is going to take.
I need internet for work/study/Counter Strike The main reason I wanted to transfer was the fact that it should be relatively painless. It seems like I have not been connected to the exchange at all. Please, could you update me or escalate it further?
Re: Major issue, should have been activated yesterday, no signal at all..
10-02-2017 3:21 PM
10-02-2017 4:42 PM
Is there any timeframe? Is it likely that this issue will be resolved this weekend?
11-02-2017 8:14 AM
I've checked your fault report and I can see that your fault has reached past point of no return, which indicates an engineer should be assigned shortly. I expect it to either be today or Monday.
11-02-2017 8:53 AM
11-02-2017 8:59 AM
Awesomeness, thanks for the update.
11-02-2017 2:14 PM
Ok, so BT Engineer had to call in a mate to help him with the cable pole. One of the two cables on my line was corroded and some connector had to be replaced. He tested the line afterwoods and since I'm about 20 meters away from the cabinet, I'm getting nearly full 80/20
There was a little issue with getting the router to connect, I had to input my details manually as the automated setup would not work. Currently testing it, about to launch Counter Strike GO to check my ping and see if there will be any interruptions.
Overall I am very bloody happy that someone at plus.net managed to get the BT Openreach engineer here on Saturday and fixed the whole issue, brilliant customer service! I'd buy you guys a beer if you are ever in Newbury
11-02-2017 2:53 PM
Yay, thanks for the update. I've checked the engineer notes and yeah there appeared to be a high resistance fault on the DP.
Haha, I'd love to take the credit but I think it was more of luck that there was pretty good engineer availability in your area.
Happy you're back up and running at a pretty nice speed.
11-02-2017 3:56 PM
Welcome both to Plusnet & this excellent community forum. From my experience the first class service you have received has been the norm in the nearly 5 years that I've been a Plusnet customer.
