Major fibre connection issues
JasonAce
I thought maybe with everyone working at home in March / April everyone had issues but I have two fibre connections (on separate lines) and one is fine.
The other one plus.net is not. I can use it normally if I use a VPN but without this many websites and apps simply fail to connect.
What is going on?
I have spent hours calling customer services and have not once got through over last 4 weeks.
I'd like a refund, issue fixed and then maybe I'll stay a customer - been one for nearly 20 years!
Thank you
4 REPLIES 4
northwayk
Re: Major fibre connection issues
I signed up to a new contract with Plusnet last month, moving from another provider. The connection of my fibre is also poor, drops numerous times a day and I have similar issues to you. Any help or advice from plusnet would be very much appreciated.
MatthewWheeler
Fixes: 405
Thanks for your post @JasonAce
We've tested your line and we can't see any issues remotely.
Can you advise if you're still having issues?
@northwayk
I'm sorry to hear you're having connection issues,
Our tests are showing an issue that requires an engineer visit for further investigation
Can you raise a fault here and then post back once you've done so?
 Matthew Wheeler
northwayk
@MatthewWheeler
When I click on the link its says DNS not found.
Kristy
MatthewWheeler
Fixes: 405
Thanks for getting back to us @northwayk
Can you try accessing it again?
 Matthew Wheeler
