Major fibre connection issues
- Major fibre connection issues
30-08-2020 8:49 PM
I thought maybe with everyone working at home in March / April everyone had issues but I have two fibre connections (on separate lines) and one is fine.
The other one plus.net is not. I can use it normally if I use a VPN but without this many websites and apps simply fail to connect.
What is going on?
I have spent hours calling customer services and have not once got through over last 4 weeks.
I'd like a refund, issue fixed and then maybe I'll stay a customer - been one for nearly 20 years!
Thank you
Re: Major fibre connection issues
30-08-2020 9:20 PM
02-09-2020 1:05 PM - edited 02-09-2020 1:22 PM
Thanks for your post @JasonAce
We've tested your line and we can't see any issues remotely.
Can you advise if you're still having issues?
I'm sorry to hear you're having connection issues,
Our tests are showing an issue that requires an engineer visit for further investigation
Can you raise a fault here and then post back once you've done so?
02-09-2020 1:21 PM
02-09-2020 3:56 PM
Thanks for getting back to us @northwayk
Can you try accessing it again?
