Macbook not connecting to wi-fi when waking from sleep.
- Re: Macbook not connecting to wi-fi when waking fr...
13-03-2017 6:04 PM
Whenever I wake up my Macbook Pro from sleep, the wi-fi is failing to re-connect.
My router name is showing in the wifi menu; PLUSNET-SHXX; so I try and choose my Plusnet network manually, and it prompts for the password. It then keeps telling me the password’s wrong, every single time. It’s not. I’m reading it off the box. the password has been correct since I first set up the router.
To get back a connection, I have to leave the computer awake for about 3-5 minutes, before trying again to manually choose the wi-fi network, at which point it tend to start working again (with no extra password prompts!)
This can’t be to do with the strength of the network/distance, because it does the same when I’m right in front of the router. And it seems to just be when waking the laptop.
I’ve ensured my Plusnet is at the top of the “preferred networks” in wi-fi settings, but other than that I’m at a loss of what to do.
When I had Virgin Media, it immediately reconnected to my home network when the computer woke, with no long wait nor intervention from me.
Surely this isn’t normal?
Re: Macbook not connecting to wi-fi when waking from sleep.
13-03-2017 7:08 PM
If you haven't already I'd first try changing the wireless channel by logging into your router interface at http://192.168.1.254 and, assuming you're using the Hub One, to try splitting the 5Ghz frequency from the 2.4Ghz.
If you need any guidance on how to do this, this should help: https://www.plus.net/help/broadband/router-user-guides/
Feel free to let us know how you get on.
13-03-2017 7:42 PM
13-03-2017 8:14 PM
13-03-2017 8:48 PM
Thanks again. That seems to connect more quickly to the original one. Should I be able to join newly-appeared 5G network too? When I try it, it tells me the pass is invalid, but still kicks me off the original conenction. Or do I have to leave the 5G redundant?
13-03-2017 9:57 PM
You should be able join the 5G network using the same wireless key. I'd verify the key in the 5Ghz settings.
Also, how far are you away from the router? Whilst this new wifi network is faster/more stable the range is considerably shorter so if the signal is weak you may have problems connecting.
13-03-2017 10:17 PM
@Anoush wrote:
No problems. Happy to hear that splitting the networks has fixed the issue.
The wireless key on the box is the same as that's showing in the router settings, exactly the same letters/numbers in 2g and 5g.
I just tried adding the new separate 5g wifi to my phone, and it accepted the same password with no problem.
I had wondered about distance from the router, but, having been downstairs earlier, I'm now sitting with the box a couple of meters in front of me & my Macbook somehow is still being (partially) awkward with the pass key
13-03-2017 10:28 PM
I'd try changing the wireless channel for the 5Ghz network and then test your Mac with the 5G after each channel change.
14-03-2017 12:24 PM
Well today, its being a little less temperamental and it is [on most tries] connecting to the 5G network. If it becomes a problem again, I'll try changing the wireless channel, though I'll need to look in the help section see what I'm meant to change it to!
Thanks again.
14-03-2017 12:53 PM
@p0mme - You may also want to disable IPv6 on your Wireless Interface, so from a root terminal:
networksetup -setv6off WiFi
If this doesn't work for your version of OSX try :
networksetup -setv6off “WiFi”
You may need to select this “Off” option in your TCP/IP Network config as seen here:
