MacBook Pro Updates and Factory reset
tracer10
I’m not sure if anybody else has had this problem but whenever I use my Plushet connection to do an apple update or factory reset using my Plushet connection or at my parents who have Plushet fibre also.  The download fails.
So so as a lost resort I connect my MacBook Pro 2017 to my phones Hotspot and it downloads and installs fine also is fine when I use my friends internet but different provider.
Does Plusnet have a problem with apple updates..  Also have a problem when at home and my iPhone connects to my WiFi as often can’t open websites so end up turning off the phones WiFi.
Looking like Plusnet just don’t like apple products as another friend having same issue.
10 REPLIES 10
notmyname
Re: MacBook Pro Updates and Factory reset
tracer10
Thats great ill try that, thanks
notmyname
Any joy?
Kelly
Fixes: 9
We've had a staff member replicate this issue.
Kelly Dorset
Ex-Broadband Service Manager
MasterOfReality
Fixes: 57
@tracer10 - did the IPV6 suggest from @notmyname help at all?
Thanks,
MoR
Fixes: 1,483
Or split the the two wifi bands.
We have various mac's that have no issue updating, so it's not a PN wide issue.
tracer10
Apologises I sent a reply but unfortunately it did not post.  Unfortunately it did not work as I had already erased the Mac drive for reset.
The fix did say though some problems connecting to the WiFi but my Mac never has this problem other than during factory reset but connects fine to my phones hotspot and also to my brothers house which is Sky.
OskarPapa
Fixes: 65
Hi @tracer10, thanks for getting back to us.
To clarify, did the disk wipe help to fix the issue, or is it still ongoing?
tracer10
Many thanks for your support and quick reply,   but no Unfortunately still not sorted it is always when I go to use factory reset.  Works fine when I use three mobile hotspot.
Fixes: 1,600
Could you try the steps here and also here letting us know how it goes?
If you're still having issues is there any way you could connect your Mac into the router via an ethernet cable to try?
