Mac keeps dropping WIFI connection
- Re: Mac keeps dropping WIFI connection
02-02-2015 11:27 AM
Hi All
My Mac running OS X 10.10.1 keeps dropping the WifI connection to my Plusnet router. The router/openreach modem is plugged into our master socket.
It only happens on my Mac as I have a windows laptop (from work) which continues to hold the connection when the Mac drops. They're right next to each other.
Any ideas?
Any ideas?
Message 1 of 6
(1,526 Views)
5 REPLIES 5
02-02-2015 11:29 AM
Can you see any errors when it drops in the Console?
Message 2 of 6
(974 Views)
02-02-2015 11:45 AM
upgrade to 10.10.2 and see if that helps, it has Wi-Fi fixes in it.
Message 3 of 6
(975 Views)
02-02-2015 11:48 AM
Have a run through this site http://osxdaily.com/2014/11/19/os-x-10-10-1-wi-fi-connection-issue-troubleshooting/
You have also got a good range of tools on a mac, use "Wireless Diagnostics" by pressing alt + clicking the wifi icon, you will see Wireless Diagnostics.
Edit:gramar.
Edit:gramar.
Message 4 of 6
(975 Views)
02-02-2015 11:54 AM
Thanks will update and try the tools to see what what happens.
Message 5 of 6
(975 Views)
02-02-2015 4:01 PM
ran the diagnostic things by holding alt and clicking the wifi icon and it did pick up a connection loss. However, the report won't open as it doesn't know what programme to open with. Not very helpful.
So also after updated OS X it still drops.
Puzzled.
Puzzled.
Message 6 of 6
(975 Views)
