MTU settings for Vigor 2860
- MTU settings for Vigor 2860
01-07-2015 12:02 PM
Can anyone tell me the correct MTU settings for a DrayTek Vigor 2860 router (connected direct, no BT modem)?
I'm using 1442 at the moment and things are working but is that the highest I can go? I've tried 1458 and 1492 but they won't work.
Can someone confirm that 1442 is the correct setting or do I have a problem somewhere?
Thanks.
Thanks.
Message 1 of 2
(1,957 Views)
1 REPLY 1
Re: MTU settings for Vigor 2860
01-07-2015 12:28 PM
My 2860n is set to 1492. I think this may be the default as I don't recall ever changing it.
I have not noticed any issues...
Message 2 of 2
(1,534 Views)
