Showing results forΒ
Search instead forΒ
Did you mean:Β
MSO
rongtw
Fixes: 12
MSO
Aparently there is a MSO , major service outage .
Bradford this morning from 06.27 estimate time for fix is 00.00 tonight πŸ˜•
As there is nowt on service status yet I put this here πŸ‘
Ps phone was answerd within 20 mins nice chap J##h helpful
Ps musak is too Loud
Fixes: 31
Re: MSO
Thanks for that @rongtw, that might explain why I can't get access to my VoIP server in TeleHouse.
rongtw
Fixes: 12
Re: MSO
https://status.zen.co.uk/broadband/fault-outage-details.aspx?reference=103903
Look here πŸ‘
rongtw
Fixes: 12
Re: MSO
Well that was quick ,, Up and running again Smiley
Fixes: 31
Re: MSO
Not for me, and looking at that link it shouldn't have affected me. But I still have an outage as I can't get to my email or VoIP servers.
rongtw
Fixes: 12
Re: MSO
Did you see the update Mook ?
UPDATE Service has been temporarily restored but further work required which will cause loss of service again
Fixes: 31
Re: MSO
Yes, but that link pertains to Zen, to which I have no relation. I can trace route to a peer at telehouse.ukcore.bt.net but it ends there.
Fixes: 31
Re: MSO
It may or may not be related but when trying to use webmail I'm seeing this a lot.
rongtw
Fixes: 12
Re: MSO
 Try this link Smiley
https://btbusiness.custhelp.com/app/service_status/
Fixes: 31
Re: MSO
Thanks @rongtw, but there is nothing in there that should affect me considering I can trace route as far as Telehouse where my hardware is installed. So I'm suspecting there is a broken switch / router somewhere along the remainder of the line.
Fixes: 31
Re: MSO
Just had an update from Telehouse, it turns out there is a partial power outage that is being investigated, so will hopefully have a quick resolution.
rongtw
Fixes: 12
Re: MSO
Looks like they were doing something this morning as well
http://www.thinkbroadband.com/ping/share/2bc025dde1295967ea696296dd74974f-16-11-2016.html
