MAC Address Filtering - Can't find it ...
- Re: MAC Address Filtering - Can't find it ...
06-04-2015 11:02 AM
Apologies if this has been asked and answered before. I tried searching, but wasn't having much joy.
I'm currently using the Sagemcom 2704n router that PlusNet provided on joining. With other routers I've always been able to set up MAC Address Filtering. I can't seem to find the option on this one. Can anyone point me in the right direction?
Thanks in advance.
06-04-2015 11:08 AM
06-04-2015 11:11 AM
There are options for blocking known (and currently connected!) devices, but I can't see anything beyond that.
06-04-2015 11:25 AM
07-04-2015 9:48 AM
07-04-2015 9:52 AM
I've included a link to the relevant support page below
http://www.plus.net/support/broadband/hardware/plusnet-2704n-advanced.shtml
07-04-2015 9:59 AM
Quote Access Control allows you to block Internet access to specific devices that are connected to your router.
To start using it, first tick Access control feature enable and press Apply.
From there, choose the device you want to block, set a time period for the blocking (this will apply every day) and then click Add.
To remove a blocking rule, tick the relevant box in the Delete column and press Apply.
So it would appear that you *can't* do this through the advanced settings.
07-04-2015 10:01 AM
07-04-2015 10:11 AM
As it appears the router they have supplied is fundamentally flawed in that it appears it doesn't allow a very basic security setting I suggest you ask for one of the old routers. See attached settings options.
07-04-2015 10:17 AM
I'm checking if this is possible and I'll post back as soon as I know.
[EDIT]
After checking with our products team I can confirm it isn't possible to enable MAC address filtering. Sorry for any inconvenience caused by this.
07-04-2015 11:25 AM
07-04-2015 3:27 PM
Somewhat perversely, I'm now wondering if I can get my previous TalkTalk router to play with PlusNet. Will start another thread for that if I can't get it working. I've got a Netgear router somewhere but that's only -G rather than -N.
07-04-2015 4:24 PM
Steps back in amazement and shock
The very basic functionality under security on the TG582n has been left out so if somebody manages to get your wifi password - by looking behind the router and the admin password they can play absolute havoc with the router settings
To say that I am appalled is putting it mildly
In my opinion all these routers should be immediately flashed with an updated firmware which will give the bare minimum of security
08-04-2015 10:40 AM
08-04-2015 10:42 AM
EDIT
Just tried and it doesn't offer anything related to MAC address filtering
