Lower then estimated upload speed
Sunzz
Hi there, so i was with BT infinity and i was getting around 50 mb download and 6 mb upload, i need the upload more sadly but BT could never do anything about it Sad i hoped switching to plusnet would sort that upload problem out but sadly not. Is there anything that can be done about my upload speed? current line speed is set at 78 mbbt wholesale test.jpgestimated.jpg
Fixes: 62
Re: Lower then estimated upload speed
is that speed test wired or wireless
Sunzz
Wired Smiley straight into the broadband slot on the master socket and ethernet to my pc
Fixes: 62
Can you pull the line stats from the router (speeds and noise margin)
Sunzz
Here it is, by the way thank you so much for the replies i really appreciate it, i was scratching my head about this when i was with bt and still now Sad how do the stats look?lineatt.jpg
Fixes: 62
No obvious problems except the upload speed is far too low
Can you try the quiet line test (dial 17070 option 2) and it should be effectively silent
Unfortunately you can't get the tone / noise margin info from that router but I suspect that there may be interference if the up to 27 tone group which is a chunk of the upstream
This is what mine looks like on 47/10 connection speeds
Sunzz
the quiet line test is literally dead quiet lol. do you think anything can be done? i feel a bit cheeky complaining about 5 mb uplaod speed, but for example a friend of mine lives a few miles away, is on the same cabinet as me ( im quite close to it ) and he gets 18 mb upload! that would be so much better to stream games and upload videos to youtube. i wonder whats wrong?
Fixes: 62
as the upload speed is less than the lowest number on the impacted range I suggest raising a fault and see what comes back https://faults.plus.net
Sunzz
Done, so il guess il see what happens Tongue wondering if i need a new line or something?
Sunzz
Could it be a faceplate issue? Say the wiring is damaged or something is it possible to get a new line etc?
MJN
Apologies for interrupting but what modem is that Jim? Looks like it gives out some handy info! (Or is it a 3rd party tool?)
vultura
It is info from DSLstats - http://www.s446074245.websitehome.co.uk. - rather than the modem/router itself.
Has anyone seen my signature, it's gone missing.
MJN
Thanks. Presumably you need a compatible modem? (Mine is the locked down Openreach one from a few years back)
vultura
Yes, it does indeed.  Sadly the OR modem won't be.
However it may be possible to unlock the unit you have and get access to some stats.  If its a Huawei HG612 you have then a unlocked firmware can be installed without too much hassle. See   http://www.kitz.co.uk/routers/hg612unlock.htm for info.
If its an ECI unit, it is not so easy sadly.
Apologies to the OP for going off-topic.
Browni
Aspiring Hero
Fixes: 47
There's a list of compatible modems in the link @vultura mentioned if you click the compatibility tab.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
