Lower than expected speeds, currently around 3mbps.
sw4mpl0rd
Hello all,
Currently experiencing pretty terrible speeds around the 3mbps up/down mark. Help!
Generally my connection seems pretty low, usually around 37mbps.
Wired connection
Bt Wholesale:
See attached image
Other info:
Phone exchange:EASTLEIGH
Estimated line speed:80Mb (This may vary between 67.7Mb and 80Mb) - Checked on 2017-07-19 22:10:06
Current line speed:42.4 Mb
5 REPLIES 5
Fixes: 1,600
Re: Lower than expected speeds, currently around 3mbps.
Whilst testing your line your router is in sync at a decent speed [that's below the estimates]
Sync Status In Sync
Downstream Speed 40.5 Mbps
Upstream Speed 9.3 Mbps
The test is detecting a possible fault which'll require an appointment
Description Impairment in copper joint detected most likely close to customer premises. Please continue to submit a trouble report.
I'd recommend running through the checks here and if that doesn't help then please complete the final step in the broadband troubleshooter as that'll report the fault to us so we can arrange an engineer visit.
Anoush
sw4mpl0rd
Hey Anoush,
I've completed the troubleshooter as requested. Thanks for the speedy response.
Fixes: 1,600
No problems Grin I've worked the ticket & updated it. Let us know once you've replied.
sw4mpl0rd
Well.... it's now worse. Dropping out way more often than it was before.
HarryB
Fixes: 256
Looking at your account, the number of drops is fairly minimal and I'm afraid likely wouldn't be classed as a fault:
 Harry Beesley
