Low upload speeds
Edubbledee
Low upload speeds
Am currently experiencing 31mbs download but only 2.21mbs upload.
Should it be this low? I've recently found online gaming to be somewhat problematic
Fixes: 62
Re: Low upload speeds
The odds are that you are on Fibre not Fibre Extra and for that the speeds are up to 40/2
It shouldn't affect gaming at all
SpendLessTime
Aspiring Hero
Fixes: 80
Are you using WiFi or cable to the router?
What model of router and what devices for the gaming?
What gaming servers are you using?
Do it happen at certain times only (8pm-10pm for example)?
As @OldjimOldjim says, the speed shouldn't be the issue (assuming that the line isn't being used by lots of people at the same time)
Fixes: 165
@Oldjim and @SpendLessTime are correct, the upload speeds on your package are up to 1.9Mb/s so I wouldn't expect to see anything higher than you're currently getting. That should still be enough to game without any issues unless your trying to stream your games online.
 Chris Parr
 Plusnet Staff
Edubbledee
I'll have a look to make sure nothing else is feeding off the wifi, I always notice it gaming in the evening on the ps4, stutters occasionally and it displays a low connection speed message on the screen. Thanks for the info though people!
danludlow
Sorry if monotonous, but why don't Plusnet make the basic package 50/10 as BT seem to be? Cost effective and useful. If losing revenue of 80/20 package is the fear why not make the Extra package truly Extra, and have enhanced support as a feature? How many would pay a small amount more if included was quicker support response? Make 80/20 a premium package, throw in a few features for good measure, and it will sell, I'm sure. For those on tighter budgets 50/10 is pretty damn good in itself.
RobPN
Seasoned Pro
Fixes: 4
danludlow wrote:
..., throw in a few features for good measure, ...
You mean like PlusNet used to be a few years ago?
