Low speeds very frequently
fourtracker80
Hi there.
I've noticed a consistent regular drop in speed lately and wondered if there are any known issues with my line. It was meant to be around 40 but I'm seeing as low as 4.
Mark
1 REPLY
Fixes: 167
Re: Low speeds very frequently
Absolutely nothing wrong with the sync speeds or the stability of your connection. Can you run a BT Speedtest when the speeds slow down again?
http://speedtest.btwholesale.com/ - ensure you run the further diagnostics after the first test completes.
 Chris Parr
 Plusnet Staff
