Low speeds to estimate - With email saying its lower then normal
thedarkmaster
Hi guys
I had a problem with my fibre and when I raised a fault, a BT engineer came out and put a new installed a new line.
Now I had an email from plus net saying that my speed is lower then it should be. Just done the tests what the email has sent me to (again)
The speed I should be getting  was between 62-80mb.
I am getting 27mb.
Now with a new line installed I don't think there is a problem with my phone line.
Many thanks.
Fixes: 68
Re: Low speeds to estimate - With email saying its lower then normal
Hi thedarkmaster,
Diagnostics are showing a dropping connection fault so thanks for raising that with us.
You should hear back from our faults guys soon.
 Adam Walker
thedarkmaster
Ok thank you for the quick replay.
thedarkmaster
Any update on what is happening?
My speed has improved a little bit, but im no where near the lower end of my estimate
