Low quality netflix (Netflix asked me to contact ISP)
andy499
Hi, been on the phone to Netflix support for the last hour.
Issue: Low quality netflix (anything uncached). Image on 55" 4K TV is lower than SD. Image on phone is pretty bad, but watchable, image on PC unwatchable, all games consoles unwatchable (through 55" TV)
Resolutions attempted:
Restart internet (duh) X
Change from auto to high for image quality/data usage X
Check difference devices on wifi/powerline/hard wired X
Check on 4G (Works fine, no low image issue)
They have asked me to raise this with the ISP.
Will someone from plusnet pick this up here or will I have to call up? I believe the port netflix uses is being throttled or blocked by Plusnet.
Thanks,
Andy
81 REPLIES 81
makkurokurosuke
Re: Low quality netflix (Netflix asked me to contact ISP)
I have exactly the same problem! The quality is appalling, on both Netflix apps on FireTV stick and on the LG TV. I contacted Netflix, they said it's an issue with my ISP. I tested Netflix by connecting my TV to my 4G personal hotspot via iPhone and the quality looks great so this proves that it's something to do with Plusnet. Any help please?Huh
WillF
Fixes: 22
Thanks for contacting us about your Wi-Fi, check out the help and support page here https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
 Will
andy499
This is not a fix, “boost your wifi”?... did you even read my post?
This happens through all forms of connection.
Wired, power line, WiFi.
Plusnet is blocking/throttling Netflix port.
Please fix this rather than suggesting silly “boost your WiFi” pages.
Mook
Seasoned Champion
Fixes: 4
@andy499 @makkurokurosuke What results do you get when you use https://fast.com/
andy499
Really?... you’re asking me this?
Anywhere from 40-50 depending on device and how it’s connected...
andy499
See here for a sample of how bad the quality is on my TV
https://streamable.com/dxpfcm
Mook
Seasoned Champion
Fixes: 4
Evidently! So what makes you think Plusnet are blocking/throttling Netflix? If they are then why are you two the only ones having an issue?
andy499
Because streaming Disney plus, YouTube in full hd is fine, Netflix is fine on 4G (TV tethered to phone on 4G) and my speed is fine.
Netflix support also advised this *could* be the case.
Mook
Seasoned Champion
Fixes: 4
Is this issue present 24/7 or does it only manifest itself at night i.e. when you made the original post? What does it look like now?
The reason Netflix suggested this was probably to get you off the phone, if you were on it for over an hour!
andy499
Present consistently since yesterday.
Currently the same, please check the video I sent above and you’ll see how bad it is. Unwatchable
Mook
Seasoned Champion
Fixes: 4
Sorry @andy499 I've no intention of using the link you provided it's nothing personal it's just something I wouldn't do but I'll take you at your word as regards the quality.
What kit do you have in your house? You said you'd rebooted the router but sometimes it's beneficial to restart your whole network. Shutting everything down in Client (PC, Console) to Server (Router) order and restarting in reverse. This operation covers everything including PowerLine Adapters, Switches etc.
You're maybe thinking that this, at best, is pointless, but when you have nothing to lose and it has worked in the past for others surely it's worth a try.
makkurokurosuke
Unfortunately I have the same problem as the OP. It's been happening since yesterday. As a prove that it's something to do with Plusnet, I tethered my phone 4G connection to my TV and streamed without problems. When I switched back to home WiFi, it's pixelated again.
Mook
Seasoned Champion
Fixes: 4
To be fair @makkurokurosuke that doesn't really prove it is Plusnet's fault, the routing used to get to the Netflix servers will be totally different for the two Networks.
makkurokurosuke
Well, it also doesn't prove it isn't Plusnet's fault, does it? Can you please tell me how could I prove it one way or the other then?
