Low ip profile
musicman2019
Low ip profile
I have been with plusnet with June but my speed seems to be getting slower. With my previous provider I was getting over 21 mbps download and 2 Mbps upload Now it only 17Mbps  the upland is about the same. I looked at my profile and it could be higher.  Thanks
Downstream: 17.2 Mbps
Upstream: 2.116 Mbps
10 REPLIES 10
musicman2019
Re: Low ip profile
MIDDLETON IN TEESDALE is served by Cabinet 2
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 24.8 15.4 3.7 2 13.1 Available Available --
VDSL Range B (Impacted) 24.4 13.8 3.7 1.8 10.1 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 2.5 -- 1 to 4 Available -- --
ADSL Max Up to 2 -- 1 to 3.5 Available -- --
Fixed Rate 1 -- -- Available -- --
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps) 17.99
Max Upstream Observed Speed (Mbps) 2.05
Observed Date 2019-12-01
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap U
VRI N
NTEFaceplate N
Last Test Date 05-12-2019
TheMightyAJ
Fixes: 126
Re: Low ip profile
Hi @musicman2019,
I'm sorry to hear that the speeds not quite achieving the most it could be. Having tested your line today I can see that the speeds are definitely at the rate you're reporting, however this is within the estimated range for your line. As such, we're unable to do much to help improve the speeds, as there isn't currently a fault with the service.
With that having been said, I would recommend setting the router up within the test socket in the property to see if this helps at all. We have a guide on how to do this here.
 Alex H
musicman2019
Re: Low ip profile
Hi Thanks for checking the line. My router is already connected to the master socket.
I know it in the range but it is the bottem of the range and as i said before the previous provider was always above 20 and mainly 21. How do i check my ip profile? I can't see it when i try
http://speedtest.btwholesale.com/
Is there another way.
Last time I checked it was set at 17.2 could this be reset?
TheMightyAJ
Fixes: 126
Re: Low ip profile
Hi @musicman2019,
Just to confirm, the current IP Profile is set at 17.2Mbps down, though this is the rate it should be set currently and making any changes wouldn't necessarily improve the download speed.
 Alex H
musicman2019
Re: Low ip profile
Well it has done in the past!! If the profile is set at 17.2 my internet cannot be any faster then that even if the line can cope with a higher speed. when i have set higher my speed has increased.  So it still does not explain why i got higher speed with my other provider?
At this rate i will not be staying with plusnet. In the past you have reset my ip profile? so why not now?
Fixes: 1,600
Re: Low ip profile
Thanks for getting back to us @musicman2019
I'm sorry to see you're experiencing speed problems. I think there's some confusion here about your IP profile. This isn't something we've got any control over, as it's set automatically to be just below your physical sync speed.
Your sync speed is what's determined physically between your router and the cabinet (The green box in the road). Unfortunately again we've no control over this for fibre, unlike for standard broadband where we can change the SNRM.
Upon further investigation I can see your sync speed at 18mbps which explains the IP profile, however I can also see your speeds are artificially restricted by the dynamic line management(DLM) software at the cabinet.
As line tests aren't showing any causes for this, I've arranged for a remote DLM reset to be carried out, which should be within the next 2 to 3 working days. Let us know how your speeds look by the close of play on Monday.
musicman2019
Re: Low ip profile
Hi Sorry for not getting back to you.
Yes getting better speeds now.
i know it does seem a lot but makes a big difference to us.
thanks
  Connected
Connection time: 1 days, 20:16:30
Downstream: 19.72 Mbps
Fixes: 1,600
Re: Low ip profile
No problem @musicman2019 that’s good to see your speeds are higher now. Thumbs_Up
Let us know if there’s anything else you’d need help with.
Fixes: 1,600
Re: Low ip profile
Hi @musicman2019
I've tested your line and I can see your router getting a more improved speed of 24mbps so I've increased a profile on your account to reflect this. Can you reboot your router and retest your speed? You should see even higher after this.
Upon testing your line, we're also detecting a lot of errors so we've passed this to the diagnostics team at Openreach for further investigation. Once I've got another update within the next 24 to 48 hours I'll let you know.
Fixes: 1,600
Re: Low ip profile
Hi @musicman2019
Our suppliers have completed work to alleviate the errors and line tests are passing now.
I'm afraid this has dropped your speeds down to 18mbps from the 24mbps, I'd suspect this is because your line can't run at 24mbps without generating errors. Unfortunately as these speeds are within the current expectations of your line between 15.4mbps and 24.8mbps, there's not much we'd be able to do to investigate further.
To rule out any internal phone wiring affecting your broadband connection I'd recommend carrying out the steps Here to connect your router into what's known as the test socket which is behind the faceplate of the master socket.
