Low download speed
- Low download speed
Low download speed
15-12-2020 11:06 AM
My current plan has a minimum guaranteed speed of 57.7mbps but when I do a speedtest I only get around 20 or even less. I have got a replacement hub one and that fixed it for a few days but my speeds are now back to being a third of what I'm supposed to get. Could you do a line test to see if there is a problem with the line because I can't think of anything else that could be causing it.
1 REPLY 1
Re: Low download speed
16-12-2020 12:00 PM
also restarting the router seems to fix the problem for a couple of days before the problem comes back again
