Hi
I recently switched to plusnet and I’ve noticed my sync seems to be on the low side as I’m currently only synced at about 50/15 whereas I used to be able to get 64/20.
Strangely according to my router my max attenable rate on the downstream is 75.
Is it normal to have such a big difference between max and current?
Here's a picture of my current router stats.
