Low Sync Speed
- Re: Low Sync Speed
Low Sync Speed
25-09-2017 12:03 AM
Currently have an issue with the phone as it's permanently engaged, can however dial out without an issue.
I switched from Sky to Plusnet on the 18th September and am not receiving the speeds expected. My estimated line speed is 69Mbps but I'm not getting close to that...
I've ran BT's speed test three times (direct connection to router) and also have my line stats....
Run 1:
Download Speed (Mbps): 53.66
Upload Speed (Mbps): 15.30
Ping Latency(ms): 22.25
Run 2:
Download Speed (Mbps): 53.64
Upload Speed (Mbps): 15.24
Ping Latency(ms): 20.13
Run 3:
Download Speed (Mbps): 53.65
Upload Speed (Mbps): 13.98
Ping Latency(ms): 21.50
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) ----------- Running Mode : 17A State : SHOWTIME DS Actual Rate : 57704000 bps US Actual Rate : 18906000 bps DS Attainable Rate : 56171336 bps US Attainable Rate : 18906000 bps DS Path Mode : Fast US Path Mode : Fast DS Interleave Depth : 1 US Interleave Depth : 1 NE Current Attenuation : 18 dB Cur SNR Margin : 5 dB DS actual PSD : 7. 6 dB US actual PSD : 13. 7 dB NE CRC Count : 26 FE CRC Count : 44 NE ES Count : 9 FE ES Count : 24 Xdsl Reset Times : 0 Xdsl Link Times : 1 ITU Version[0] : b5004946 ITU Version[1] : 544e0000 VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support] Power Management Mode : DSL_G997_PMS_L0 Test Mode : DISABLE -------------------------------- ATU-C Info --------------------------------- Far Current Attenuation : 24 dB Far SNR Margin : 6 dB CO ITU Version[0] : b5004244 CO ITU Version[1] : 434da48c DSLAM CHIPSET VENDOR : < BDCM > > vdsl status more ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) ----------- Near End Far End Note Trellis : 1 1 Bitswap : 1 1 ReTxEnable : 0 0 VirtualNoise : 0 0 20BitSupport : 0 0 LatencyPath : 0 0 LOS : 0 0 LOF : 0 0 LPR : 0 0 LOM : 0 0 SosSuccess : 0 0 NCD : 0 0 LCD : 0 0 FECS : 1150 1788 (seconds) ES : 9 24 (seconds) SES : 0 0 (seconds) LOSS : 0 0 (seconds) UAS : 30 5177 (seconds) HECError : 0 0 CRC : 26 44 RsCorrection : 0 0 INP : 0 0 (symbols) InterleaveDelay : 0 0 (1/100 ms) NFEC : 254 255 RFEC : 14 16 LSYMB : 5030 15464 INTLVBLOCK : 127 255 AELEM : 0 ----
Is there anything obviously wrong on here?
I did have a engineer visit scheduled for Tuesday, however, I cancelled it as the phone started working again, but now it's not. Think I should re-schedule one...
Re: Low Sync Speed
26-09-2017 2:11 PM
I've just taken a look at your account and can see we've arranged for an engineer to come and see you tomorrow.
I hope that gets the problem fixed but do post back here if not or if we need to follow up on anything for you.
Re: Low Sync Speed
27-09-2017 11:18 AM
Openreach have visited and found no faults.
The issue with the phone being constantly engaged is down to the porting of the phone number itself I'm told.
Re: Low Sync Speed
28-09-2017 3:52 PM
Thanks a lot for the update, a lot of speed and disconnection faults we see around this time of year can be weather related. As things are looking more clement across a lot of the UK today are things any better with your speeds?
