Low SNR
DOC1
Re: Random Reboot
Hi @adam945 Thanks for reply
Yes I get what you are saying I would prefer to conduct tests on my side first . My PlusNet router packed in a while back so I purchased a different router so I would like it if you was to send me a new router so I can do the tests on that just in case its the router I am currently using
Fixes: 1,600
Re: Random Reboot
Thanks for getting back to us @DOC1
Ah OK. No problem, I've sent you a new router free of charge now you should receive within the next 3 to 5 working days.
Let us know how it goes once you've got it.
DOC1
Re: Random Reboot
Ok @Gandalf  Thank you. I Will get back to you when I receive it.
Fixes: 1,600
Re: Random Reboot
No problem @DOC1, sounds like a plan
DOC1
Re: Random Reboot
@Gandalf
It Sure Does.
DOC1
Re: Random Reboot
Good morning @Gandalf
I am letting you know that I received the router this morning so what do I do next?
Do I Set it up normally?
TheMightyAJ
Fixes: 126
Re: Random Reboot
Hi @DOC1,
Yes please, just set it up normally and we'll see how it performs from there.
 Alex H
DOC1
Re: Random Reboot
Ok thanks for reply @TheMightyAJ  I will do that now.
DOC1
Re: Random Reboot
Hi @TheMightyAJ
All up and running now. it took a while because somehow under 'IP settings had changed IP assignment to manual but changed back to auto and all is good now .
adam945
Fixes: 113
Re: Random Reboot
Great stuff @DOC1 Smiley
See how the line performs over the next 72 hours or so and let us know if you're still having any problems.
 Adam
 Plusnet Help Team - Leeds
DOC1
Re: Random Reboot
Ok @adam945
I shall do thanks for your help
DOC1
Re: Random Reboot
Hi @adam945
I have been using the router you sent me and I am getting ( CWMP: session closed due to error:) Timeout errors about 7 now in total also I had one reboot. is this normal? On the plus side my speeds have improved back up
adam945
Fixes: 113
Re: Random Reboot
Hello @DOC1
To be honest that error could mean anything, though I've run some checks on the line which do not appear to be showing any definitive issues at all since 27/06/2021. On our end, the connection appears to be stable for the last 5 days as well.
Monitor your connection over the next few days and let us know how you get on. If you haven't already, see if you can remove your face plate on the master socket, and connect your router directly into the test socket which lies behind it. Avoid turning your router on and off and see how the connection fairs. There's still an open fault Ticket on the account, so if the issue does not correct itself over the next few days, let us know and we'll raise it to Openreach.
 Adam
DOC1
Re: Random Reboot
Hi @adam945
Thanks for getting back to me. I will connect the router to the test socket now and see how it goes from there.
And I will let you know if I am still getting issues
Fixes: 1,600
Re: Random Reboot
No problem, let us know how you get on Smiley
