Low IP Profile
bbennett69
Low IP Profile
Hi Plusnet Community,
My download sync speed has been a constant 39999 for a long time now, probably over a year. Which is great, but the issue is my IP profile is stuck at 35.3 Mbps. How do I go about getting this profile unstuck please?
Thanks Brian.
6 REPLIES 6
bbennett69
Re: Low IP Profile
Never mind my contract is up next month, I guess I will just move to another provider shame. Posted an official question to the Plusnet help with no response and on here with no response either.
Edit: I will try the official Plusnet help one last time, but if any admins here could help that would be great.
RPMozley
Fixes: 13
Re: Low IP Profile
We’re in pretty much the same situation ~39940 kbps sync, speed profile stuck on 35.2 mbps for weeks now. I don’t know what’s happened to the automated update system, seems to have gone wonky.
That's RPM to you!!
adamwalker
Fixes: 221
Re: Low IP Profile
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
 Adam Walker
bbennett69
Re: Low IP Profile
Just as an FYI, I've raise this issue 3 times now with faults.plus.net, never had as much as an acknowledgement never mind a response. Really regretting having resigned, I should have moved.
Issue is still there, still only getting 3.5MBs from my 40Mbs synced connection. I used to get 4.4/4.5MBs from this same connection speed for both BT and Sky. The IP Profile is still stuck.at 35.3
Any suggestions for the best course of action for me to contact Plusnet about this since the above URL is unresponsive please?
Thanks Brian.
Mads
Fixes: 79
Re: Low IP Profile
Hey @bbennett69, thanks for getting back to us.
 I'd recommend raising a speed fault on the account as per the previous response - it doesn't appear as if the questions/steps requested during the fault raising were followed and so the fault closed automatically - feel free to give this thread a nudge once done and we can look into the fault for you.
Thanks.
bbennett69
Re: Low IP Profile
You are 100% correct, I didn't follow all the steps I stopped after the first page each time. I feel so stupid now, thanks for the help. I've now correctly raise the issue and receive an E-mail acknowledgement.
