Low Download Speeds
- Re: Low Download Speeds
Low Download Speeds
02-05-2018 12:22 AM
We've been having some real problems with our download speeds and they have consistently been way below the minimum guaranteed speed of 65Mb and barely reaching 30Mb and hovering around standard non-fibre speeds. We were wondering if there is perhaps something causing these issues and would like you guys to help us out with our issues.
Many thanks!
02-05-2018 1:38 PM
Hello @gcpatty
Sorry to hear you are experiencing problems with your speed. I checked it from our side and everything seems to be working as we'd expect. Can you advise if the speeds you are seeing are solely on wireless connections, or wired connections also?
02-05-2018 1:41 PM
Thanks for your reply. It's solely wireless connection that we use.
03-05-2018 12:45 PM
