Lost internet connection - fibre broadband
- Lost internet connection - fibre broadband
24-04-2020 12:58 PM
Re: Lost internet connection - fibre broadband
26-04-2020 1:45 PM
I am sorry to hear of the problems with your broadband.
I can see that you now have an active connection, but the broadband has dropped out frequently. I've ran a test on the line but have been unable to find a fault that would be causing the issue. If you haven't already done so, I would first advise having a run through our troubleshooting steps here.
26-04-2020 2:10 PM
Thanks for your reply. We do have a connection now but it keeps dropping out.
I've worked through the troubleshooting as far as I can. However the next step suggests connecting our laptop direct to the modem, but our laptop doesn't have an ethernet connection port.
Is there anything else we can try?
Cath
28-04-2020 2:28 PM
Hi @Purplecath3, thanks for getting back in touch. If the basic troubleshoot steps above don't look to have helped then I'd recommend when you notice further drops persist to set your router up in your test socket to help determine the next best course of action. This can be done by plugging the connection into your test socket which is under the face plate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Given how intermittent the drops look to be effecting your connection I'd advise if it's not clear straight away to leaving your connection in this set up for 24-48 hours to see if there's still a problem. Let us know how it goes.
30-04-2020 1:59 PM
We have tried plugging the router directly into the test socket and have left it in the test socket for the past 2 days. Unfortunately this has not resolved the problem . Internet is still regularly dropping multiple times each day.
Further advice please?
Cath
06-05-2020 8:01 AM
Is anyone there? We're still having the same problem and no reply from anyone at Plusnet since last week.
Cath
20-05-2020 4:26 PM
Are we expected to pay normal rates for this service?
20-05-2020 5:03 PM
Thanks for getting back to us @Purplecath37 and apologies for the delayed response.
I'm sorry for the issues with your connection. Before we book an engineer to investigate further, I think it'd be worth checking your router (and modem because I believe you may still be using the Openreach modem and Technicolor router from long ago) is still in working order. The best way to do this is to replace it.
We can send you an up to date router that has a modem built in but we may need to recontract you in order to send one out free of charge. To arrange this I'd recommend calling our customer options team on 0800 013 2632. If you prefer to buy your own modem/router, the settings Here should help you set it up.
If you're still having issues, could you reply to this ticket with some availability for an engineer to visit? The available timeslots are 8am to 1pm, or 1pm to 6pm. The engineer will contact you on the day and do their best to investigate the fault externally. They'll only go inside your property after taking the necessary precaution and agreeing this with you.
