Lost around 20Mb of download speed since contract change
clownfish
Last week I changed my Plusnet contract as Plusnet advised my previous contract has expired and signing up for a new one would save me £4.99 a month.  I also got a Hub One router sent as part of this which was also Plus Nets idea as I they decided the fault I was experiencing at the time was a router or openreach modem issue.
Prior to this I was getting download speeds of 62-65Mbits, now its around 45Mbits and shows no sign of edging back up.
Here are the results of my testing.  BT Speed test:
Download 47.79.66Mbs, upload 15.18Mbs, ping latency 23.13
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
80
62.5
20
20
55.9
Available
Yes
Yes
VDSL Range B (Impacted)
73.4
44
20
14.4
35
Available
Yes
Yes
It seems I am outside range A and only just in range B for downloads.  Uploads are slower then before as well as I would regularly hit around 19.
Nite the router is showing that the connection has been up for just on 4 days which is slightly odd because as far as I am aware the router has not been powered down and neither have we had a power cut
So the simple question is, does the above warrant raising a ticket or should I wait a few more days to see if speeds return to normal?
Fixes: 485
Re: Lost around 20Mb of download speed since contract change
It looks like a fault report has already been raised. Likely we'll need to arrange an engineer visit.
I'll reply to your fault ticket
clownfish
Who raised the fault as a ticket because it wasn't me?
There was a previous fault raised prior to me changing contract and getting the hub one. That was due to a complete loss of connection which seemingly fixed itself as I got connection back before the hub one arrived and coincidentally on the same day my contract changed.
It is only since then I noticed the poor speeds and I myself have not raised a formal fault ticket about the issue.
I posted here to see if anyone could advise if I should raise a ticket or wait to see if things improved.
So, has the ticket been raised by plusnet based on the information I supplied above?
Fixes: 485
The ticket was raised via the Member Centre last week.
Your router is in sync below the estimates. Renewing your contract will not be the cause of that.
If you've tried the test socket then the next step would be to arrange an engineer visit.
