Loss of over 10mb in Download speeds
- Loss of over 10mb in Download speeds
- « Previous
- Next »
Re: Loss of over 10mb in Download speeds
17-07-2015 11:03 AM
Either way though, explain to us how the data is obtainble from Plusnet.
17-07-2015 11:18 AM
I'm getting pretty sick and tired of your unhelpful interjections. You used to be a very helpful poster at one time.
17-07-2015 11:25 AM
17-07-2015 11:30 AM
17-07-2015 11:34 AM
Anyhow, to be clear - if the line was failing the GEA check, then Chris would have posted this. The data you've asked for is not available and the the sync speed has already been posted.
17-07-2015 12:07 PM
The test lists sync rates and the profile, along with whether a fault report is advised and a few other lines. SNR is not on there.
17-07-2015 8:56 PM
Chris Matthew asked if the speed drop was effecting my internet usage, yes it is im having problems streaming things without getting the buffering.Why cant you ask BT/Openreach to check why my IP Profile has dropped from the speeds ive mentioned above.
18-07-2015 10:01 AM
unless your connection is well below the estimate they couldn't care less what you currently have or what you had before, sad to see but that's the facts.
18-07-2015 9:09 PM
18-07-2015 11:38 PM
18-07-2015 11:53 PM
19-07-2015 12:16 AM
- « Previous
- Next »
