Loss of download sync speed and SNR question.
Fixes: 34
First I know little or nothing about the workings of fibre so please take that into account when responding. I had to shut down my connections this morning due to the storm that was overhead. On reconnecting I see that the download speed on one of connections has reduced and the SNR Up/Down values have changed on both (although I can't remember the values I know them not to be their current ones).
I disabled each WAN before I shut the power off so will the sync speed return to the previous values? And what values are good for SNR higher or lower?
Your comments appreciated of course.
Fixes: 34
Re: Loss of download sync speed and SNR question.
50 views but no reply, so this is an unadulterated gratuitous bump. The loss on the second line seems permanent so any thoughts?
Fixes: 162
The DLM should recognise the line is stable and make alterations based on this, they do take some time on fibre and can be a couple of weeks.
In general lower = faster, higher = more stable. On lines more prone to errors you'd normally see a higher SNR to keep the line stable.
 Chris Parr
 Plusnet Staff
