Losing connection to online games.... again...
St3
Aspiring Champion
Fixes: 5
Losing connection tonight in most online games, also noticed ping has jumped from 20 to 100+ Sad Bring back the old network...
Im getting this when i try to see what gateway im on .........
Which gateway
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Issues topic in the Community forums will help us to diagnose the problem.
  • core2-hu0-18-0-0.colindale.ukcore.bt.net (62.172.103.16) 5.579 ms
10 REPLIES 10
rongtw
Fixes: 12
Re: Losing connection to online games.... again...
Ste For some reason Games were terrible for me too Sad
rongtw
Fixes: 12
Look here Ste Sad
https://community.plus.net/t5/Fibre-Broadband/Odd-TBB-test/m-p/1395754/highlight/true#M52434
St3
Aspiring Champion
Fixes: 5
Sad
St3
Aspiring Champion
Fixes: 5
Connections terrible tonight
rongtw
Fixes: 12
New network Congestion Sad
davenos
It would appear that your suffering from the same issues as quite a few of us, if you raise a fault be prepared for the following to happen,
1. Your line will be checked and found to be error and congestion free,
2. You will then be told by another agent there is no fault who will then explain that despite there being no fault its down to exchange contention/congestion.
3. This will then be followed by a message saying no fault found its your wireless settings that are the cause and thats the case even if your using a wired connection.
All of those have happened to me in the last week, so good luck and don't expect a quick fix or any fix as i've given up hope(21 weeks and counting of constant ping/packet loss/peak time slow speed issues).
St3
Aspiring Champion
Fixes: 5
I just dont understand why there is still ongoing network problems, the whole point of the new network was to free up all the conjestion, seams worse than ever now.
SteveA
I agree with you - I'm on the new network as far as I know and I've got bad packet loss, bad latency and speeds that are all over the place.
St3
Aspiring Champion
Fixes: 5
Well lucky for me im not tied into any contract, so if things dont pick up ill be moving on.
rongtw
Fixes: 12
Ste its likely to get worse before it gets better Sad  PN say they cant replicate any issues Angry
