Looking prett poor at the moment..
- Looking prett poor at the moment..
24-09-2019 7:35 PM
I've signed up for Fibre Extra broadband which was finally delivered yesterday. It is advertised as 65-72Mb with a guaranteed minimum of 60.6Mb, I'm currently getting 12Mb download which is pretty dire. The router is plugged directly into a new BT master socket so no dodgy wiring to blame and I'm running the test on a cable connected laptop so no dodgy WiFi to blame. I've had slightly better speeds during the day (but nowhere near 60.6). I'm concerned that this service isn't going to be good enough to replace the ever price increasing Virgin Media connection that I currently have also. This gives consistently 200Mb regardless of time of day.
Re: Looking prett poor at the moment..
24-09-2019 9:53 PM
Thanks for your post, @Planetcs.
We're sorry to hear of your speed woes.
On testing the line,our GEA test is showing the below:
GEA Test Detail | |||
Circuit ID | NA | Service ID | <REDACTED> |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 79.9 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
DP Type | External |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-09-24T20:21:37Z | 2019-09-24T20:36:37Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Due to the fact that we do not supply your phoneline, I'd recommend contacting the supplier and getting them to run a line test as we aren't able to run diagnostics on another providers service.
Please let us know how you get on.
25-09-2019 6:59 AM
Many thanks for your swift response. The test result looks pretty good to me with the exception of the voice fault. How would you interpret that, do you think there is a problem with the copper wire that joins my master socket to the street cabinet (which is very close to my house) - is this not BT's responsibility? My phone line contract is with ITalk at the moment so I'll get in touch with them but I'm not sure how interested they'll be in helping - I'll let you know!
25-09-2019 10:12 AM
Hi @Planetcs
They should be contractually obligated to address faults on their side as yoru WRL3 provider?
Let us know how it goes with them.
Kind Regards,
MoR
