Looking for a cheap trouble free VDSL modem
FIXED- Subscribe to RSS Feed
- Looking for a cheap trouble free VDSL modem
10-07-2018 6:09 PM
Fixed! Go to the fix.
Re: Looking for a cheap trouble free VDSL modem
10-07-2018 6:14 PM
Options
1) Used Huawei HG612 BT modem from ebay
2) TPLink TD-W9970 set to bridge mode ( https://www.amazon.co.uk/TP-Link-Wireless-Support-UK-TD-W9970/dp/B013OXVA6M ) also available in Argos - ( I currently use one of these )
3) Netgear DM-200 set to bridge mode - https://www.broadbandbuyer.com/products/26379-netgear-dm200-100eus/
Hope that helps
Post back with any queries
10-07-2018 6:19 PM
10-07-2018 6:45 PM
Try to match the chipset of what you buy to the chipset inside your cabinet. Eg. Huawei cab with broadcom chipset or ECI cab with Lantiq chipset. There are lots of posts online detailing how to find out. Sorry I don't have any to hand right now.
The TP link above has a broadcom chip I believe whereas the others are Lantiq.
10-07-2018 6:49 PM
10-07-2018 6:55 PM
I've no experience personally of the DM200 I'm afraid , there's a kb here for setting it bridge mode https://kb.netgear.com/30773/How-to-set-DM200-into-bridge-modem-only-mode.
The only problem I've had with the W9970 is that it looks awful!!
10-07-2018 7:14 PM
I have just bought the Netgear DM 200 so I will see how it goes, Thanks for all the advice
11-07-2018 1:23 PM
Let us know how you get on with your new setup.
13-07-2018 11:57 PM
14-07-2018 12:44 PM
If you can get an HG612 they are robust and just works perfectly. I put the hacked firmware on it, it never drops the connection, works flawlessly and stable.
