Logging out after changes
- Re: Logging out after changes
08-09-2015 12:47 PM
I am having a problem with settings changing after a few minutes, on the Sagemcom router. I set up an IP camera, set up port forwarding and open the firewall to the the camera. I test the connections and all is working well. However, after a few minutes the camera is not reachable and I am unable to access it remotely. I open port forwarding again, click edit, I change nothing I then click apply and the camera can be accessed again. I'm wondering if its because there doesn't seem to be log out link which should be clicked.
Any ideas please?
Any ideas please?
Message 1 of 2
(643 Views)
1 REPLY 1
11-09-2015 12:18 PM
Hi peterpi,
the router should be saving your settings.
Please try a <a href="http://www.plus.net/support/broadband/hardware/plusnet-2704n-faqs.shtml#factoryReset">factory reset</a> before trying this again.
Let us know how you get on.
Message 2 of 2
(421 Views)
