Live streaming issue?
pluke1973
While trying stream a live event the video constantly disconnects, this seems to be because the download speed fluctuates quite a lot. I have ran a Think broadband quality monitor, but not sure what the results mean? Any help appreciated
a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/d2a86a7dc72356caa62213040350eb05-12-01-2015.html"><img alt="My Broadband Ping - My fibre" src="http://www.thinkbroadband.com/ping/share-large/d2a86a7dc72356caa62213040350eb05-12-01-2015.png" /></a>
Re: Live streaming issue?
Can you give a link to to the live stream or tell us which site its hosted on?
pluke1973
It happens when using Sky go and NOW TV
I think it's an issue with Sky.
I tried downloading a film earlier this evening from Sky On Demand...3.5 hrs later it's still downloading  Shocked
MattyC
Champion
Fixes: 46
Hi pluke1973,
Couple of simple questions if you don't mind.
Are you using a wired or a wireless connection to provide this stream?
Does the download speed falter when using anything else? Or is it just when you are providing the stream?
Quote from: AndyH
On FTTP?!
Matty
Even on FTTP  Embarrassed
It's an issue with Sky and Akamai that is fairly regular persistent now unfortunately. I've had the problem on and off for the last 6 months.
pluke1973
Thanks for the reply Andy
Matty, this happens when using wired and wireless, and i dont think its just when streaming. As even when trying to connect to a website the page sometimes takes a while to load
Paul
pluke1973
this is the latest quality monitor graph, not sure what all this means?
Can you post here if you're having issues again this evening and I'll try at the same time to see if it also affects me?
pluke1973
Yes will do, but it seems to be an almost constant issue, I can download ok. But looking at it today, the speed fluctuates every few minutes for full speed down to nothing and back up again
