Line stats from HG612 Modem
- Line stats from HG612 Modem
17-04-2015 4:28 PM
These are my old stats
Stats recorded 10 Apr 2015 10:01:01
DSLAM/MSAN type: BDCM:0xa44f / v0xa44f
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 1 day 22 hours 47 min 3 sec
Resyncs: 0 (since 10 Apr 2015 10:00:28)
Downstream Upstream
Line attenuation (dB): 9.8 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 79999 20000
SNR margin (dB): 13.9 19.7
Power (dBm): 13.5 5.5
Interleave depth: 16 8
INP: 46.00 47.00
G.INP: Enabled
RSCorr/RS (%): 0.0018 0.0202
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 40924 Kbps, Downstream rate = 109184 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 79999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 13.9 19.7
Attn(dB): 9.8 0.0
Pwr(dBm): 13.5 -5.5
VDSL2 framing
Bearer 0
Here are the stats from today
Stats recorded 17 Apr 2015 15:05:59
Status: Showtime
Uptime: 2 hours 38 min 55 sec
Resyncs: 0 (since 17 Apr 2015 14:57:25)
Downstream Upstream
SNR margin (dB): 13.8 19.5
INP: 46.00 47.00
G.INP: Enabled
RSCorr/RS (%): 0.0000 0.0014
ES/hour: 0 0
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 40676 Kbps, Downstream rate = 108500 Kbps
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 13.8 19.5
Attn(dB): 9.8 0.0
Pwr(dBm): 13.5 -5.5
VDSL2 framing
Bearer 0
Only thing i see is the SNR margin has dropped slightly, would that make any difference?
I would have thought my Interleave depth would have dropped, but it's still at 16.
Re: Line stats from HG612 Modem
17-04-2015 5:32 PM
The small change might be due to syncing at a different time of day, even with a really good line like yours there will be some 'noise' at times seen by the modem.
17-04-2015 5:58 PM
17-04-2015 7:26 PM
Your line stats look really good. You are right at the top end of sync speed so you are doing very well. You must be close to the cabinet. Look at your attainable speed (109 Mbits down and 40 Mbits up). Once the faster products are available, you will be able to make full use of them. Very lucky.
17-04-2015 9:15 PM
Quote from: darklight What is the best time of day to sync (reboot) modem? to get best line stats.
Never. You're not going to get anything better than your current stats on the currently available fibre products.
17-04-2015 9:29 PM
18-04-2015 1:26 AM
But, Your and mine are much closer to the cabinet are likely to stay with max sync rate for a long while!
Here is my stats below:
Mode VDSL2
Traffic Type PTM
Status Up
Link Power State L0
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 11.7 15.7
Attenuation (dB) 11.3 0.0
Output Power (dBm) 12.5 -1.3
Attainable Rate (Kbps) 103784 35021
Rate (Kbps) 79999 20000
B (# of bytes in Mux Data Frame) 130 97
M (# of Mux Data Frames in an RS codeword) 1 1
T (# of Mux Data Frames in an OH sub-frame) 0 0
R (# of redundancy bytes in the RS codeword) 8 8
S (# of data symbols over which the RS code word spans) 0.0518 0.1554
L (# of bits transmitted in each data symbol) 21468 5457
D (interleaver depth) 16 8
I (interleaver block size in bytes) 139 106
N (RS codeword size) 139 106
Delay (msec) 0 0
INP (DMT symbol) 46.00 47.00
OH Frames 0 0
OH Frame Errors 0 0
RS Words 3901139344 4165599
RS Correctable Errors 266003 257357
RS Uncorrectable Errors 0 0
HEC Errors 0 0
OCD Errors 0 0
LCD Errors 0 0
Total Cells 3507171099 0
Data Cells 1663326359 0
Bit Errors 0 0
Total ES 0 0
Total SES 0 0
Total UAS 0 0
18-04-2015 9:18 AM
I'm not new, i've been on FTTC for just over 2 years now with plusnet, so i guess my attainable rate will stay as is, unless it starts to fill up anymore.
18-04-2015 1:59 PM
18-04-2015 3:17 PM
