Line speed
dickelliott
Line speed
Could someone please update my line speed as it's dropped to 56Mbps for no apparant reason.
Telephone number:
01403
Phone exchange:
HORSHAM CARFAX
Estimated line speed:
80Mb (This may vary between 63.2Mb and 80Mb) - Checked on 2016-06-28 10:19:01
Current line speed:
55.8 Mb
Fixes: 62
Re: Line speed
First - remove your phone number
Second - have you checked either the BT IP profile or the sync speed from your router
dickelliott
Re: Line speed
Removed my phone number now. Didn't realise that i had copied it to here.
BT line profile is 55.4Mbps
Fixes: 62
Re: Line speed
So the real question is why did your sync speed drop
Going by the fact that the Plusnet profile is higher than the BT one would tend to indicate that there was a further sync drop in the early hours of this morning
Do the router stats give any indication as to when it hapened
dickelliott
Re: Line speed
Been having problems with line spped since fitting the Hub 1 router. Changed my phone line to PN, took out their youview tv and signed up to another 2 year contract.
With my old netgear router i was getting download speeds of 56Mbps all the time. With hub 1 router speeds have varied contantly between 14 and 59Mbps. Been all over the place.
I noticed when i checked my line spped on the PN website that i should be getting between 63 and the top whack of 78. My line spped has only ever been 63 at the highest. So i was wondering why it had never been anywhere near this. Over the past few days itls been dropping and now shows it to be 55.
Can't go back to my old router because it doesn't support IPTV. Raised a fault with PN and the guy just sais it's probably interference from other things etc. I know that's not the answer otherwise it would have happened with the other router.
For 4 years no problem at all, since fitting the hub 1 nothing but trouble
