Line speed
FIXED- Subscribe to RSS Feed
- Re: Line speed
17-05-2016 3:53 PM
Hi all
I am thinking of upgrading my package to 76mb from 40mb.
I did a speed check using BT DSL line test but its saying that my line is only capable of up to 40mb on range B (Which I'm on according to this check?) and range A is up to 53mb? is it worth me upgrading and if so would PlusNet/BT move me to Range A
Fixed! Go to the fix.
Re: Line speed
17-05-2016 4:05 PM
Range A and B are line quality ratings and nothing to do with Plusnet
My figures are almost the same as yours and I get about 45Mb/s and the only reason I am on 80/20 is the low upstream rate on 40/2 and also when I first got fibre the forecast was much higher (and it was wrong)
Re: Line speed
17-05-2016 5:49 PM
I think you'll find that Plusnet will use the Range B (impacted) as the cutoff point for orders. So if Range B is 39Mb then they will only sell you 40/2.
This was pointed out to me by @MattyC in this thread https://community.plus.net/t5/Fibre-Broadband/What-speed-should-I-get/m-p/1333898#M38540
18-05-2016 9:46 AM
Based on this, we'd advertise speeds of 40/8, though it can vary around that range. As it stands, you'd get an improvement in upload speed and possibly a slight improvement on downloads.
Matty
