Line speed discrepancy?
bartstope
Hello everyone,
Just a quick question, I moved house back in December and I noticed playing around with my Hub One, these stats:
6. Data rate: 1999 / 39952
7. Maximum data rate: 15068 / 50231
8. Noise margin: 19.3 / 10.0
9. Line attenuation: 25.9 / 19.4
10. Signal attenuation: 18.3 / 19.3
The maximum data rate falls quite short of the current data rate - is this cap a hang over from my previous connection at my old house, or is it a some other type of limitation?
Fixes: 62
Re: Line speed discrepancy?
You are on the 40/2 product not the 80/20 product (Fibre not Fibre Extra)
bartstope
Thank you OldJim.
I wasn't aware of there was a different fibre product... I thought it was like ADSL these days where you get your line speed and some people are luckier than others.... i've just a look and i can indeed see it in the fibre product page. doh!
