Line speed capped?
jclau
Line speed capped?
hi can you please do a full GEA test and report the results here. Also if the line has been banded, please do a DLM reset as well. Thank you.
3 REPLIES 3
LaurenB
Fixes: 88
Re: Line speed capped?
Hiya @jclau, It looks like you are banded at 35mb and so I've sent off the request for a reset for you. I'll attach the GEA below for you.
 Lauren Barry
LaurenB
Fixes: 88
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 35.0 Mbps
Upstream Speed 7.2 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 606.5
Upstream Rate Assessment Low
Downstream Rate Assessment Low
Technology VDSL
DP Type External
Profile Name 0.128M-35M Downstream, Error Protection Off - 0.128M-7.2M Upstream, Error Protection Off
Time Stamp 2020-02-26T13:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 34.9 Mbps 34.9 Mbps 34.9 Mbps
Up Stream Line Rate 7.1 Mbps 7.1 Mbps 7.1 Mbps
Up Time 900.0 Sec 900.0 Sec 900.0 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2020-03-10T12:32:13.340+00:00 2020-03-10T12:47:13.340+00:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Lauren Barry
jclau
The line is now faster. Thank you very much.
