Line speed being capped at 20Mbps??
- Line speed being capped at 20Mbps??
12-03-2016 10:23 AM
Recently it appears artificially capped at 19-20Mbps. BT wholesale line speed test confirms it should be around 32 Mbps, I've tried others routers but there is no change to the speed.
Can anyone help with this?
Re: Line speed being capped at 20Mbps??
12-03-2016 10:48 AM
What is the exact result for the BT "IP profile" that "BT Wholesale Broadband Performance Test" -> "[Further diagnostics]" shows ?
If you login to the Plusnet "Member Centre" using this link - https://portal.plus.net/my.html?action=data_transfer_speed
what does it say there for the "Current line speed:" ?
12-03-2016 11:57 AM
12-03-2016 8:52 PM
13-03-2016 7:40 AM
Quote from: Nibiru That's odd, there was another case of this happening yesterday - "my fibre is being wrongly capped at 21megs."
Another 'glitch' relating to being moved to the new network perhaps?
@tudou, either phone or use the chat to contact support and tell them your PN. Current line speed is wrong.
They should be able to reset it immediately
13-03-2016 8:14 AM
13-03-2016 8:28 AM
Quote from: tudou I think something is still not right..
So run through the faults troubleshooter in the Plusnet Member Centre, and see if the Plusnet faults team can help.
14-03-2016 9:51 AM
Downstream Speed 28.7 Mbps
Upstream Speed 2.0 Mbps
Estimates: 32.3 to 22.4
What's general performance like? Do other speedtests do the same or are they more stable?
