Line speed Lower than estimate
Andrew_T
My downstream is currently trained in at 32mb (taken from the router GUI) which is below my estimate. Since joining Plusnet my speed has been 36-37mb which was about the same as my previous  provider.
I am in my master socket which is an NTE5C SSFP with no extensions. I work in the B.B industry and know what I am doing when it comes to diagnostics and fault finding. Openreach were working up my pole his week and I don’t know if they have done something to affect my speed but It seems like it could be them.
I am a gamer and speed is actually really important to me. Would have the faster  service if it were available to me but unfortunately it’s not and for now I am stuck with basic fibre. Could somebody please look at my line and possibly reset DLM/uncap it so I can get the best speed my line can support please?
Andrew_T
Re: Line speed Lower than estimate
I meant to include this on the original post
Fixes: 33
Sight of the Help Desk tab in the Troubleshooting section would be far helpful to anyone giving useful advice.
Andrew_T
Thanks, not familiar with the plusnet hub yet. I did wonder why I couldn’t see the SNR and min/max rates
Fixes: 33
Thanks, not much margin there for an increase. What does the DSL Checker suggest your line is capable of?
Andrew_T
I’ve been receiving 36mb since joining plusnet over 3 months ago. Only in the last week it’s dropped to 32mb. If there is an issue with my connection the max attainable estimate is going to drop. I wish I had seen this info earlier as I would have been able to see was the max achievable was when I was receiving 36mb
Fixes: 464
Hi there.
From what I can see your line isn't banded or capped: "Profile Name: 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off"
I'd recommend raising a fault to us at http://faults.plus.net so we can report this through to our suppliers and arrange an engineer to investigate further.
Andrew_T
I replaced my adsl cable and all is ok again.
Max achievable is back up and downstream is back to expected..ish
Screen Shot 2018-08-03 at 16.15.26.pnghelpdesk
Fixes: 464
Glad to see your speeds have increased!
