Line perturbation
- Line perturbation
Line perturbation
06-02-2020 12:51 PM
Following a recent line perturbation please can you provide a GEA test.
Re: Line perturbation
07-02-2020 3:00 PM - edited 07-02-2020 3:00 PM
Thanks for getting in touch @dws1900
I've provided this for you below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 22.6 Mbps |
Upstream Speed | 1.2 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Detected |
Estimated Line Length In Metres | 1499.5 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
DP Type | External |
Profile Name | 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2020-01-25T15:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 22.1 Mbps | 22.5 Mbps | 22.2 Mbps |
Up Stream Line Rate | 1.1 Mbps | 2.5 Mbps | 2.2 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 890.4 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-02-07T14:33:01Z | 2020-02-07T14:48:01Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
07-02-2020 3:27 PM
Thank you for the test results.
Prior to the perbutation which occured at 05-Feb-2020 15:48, the sync speed was
22.15Mbs DL, 2.45Mbs UL,
post the event the sync speed was
22.59Mbs DL, 1.16Mbs UL
Note the drop in the UL speed.
I waited until I received a GEA to confirm this, then rebooted the modem.
Currently the speeds are
22.35Mbs DL, 2.54Mbs UL.
I am at a loss to understand what happened here, and look forward to any ideas from Plusnet or other learned persons on the board.
