Line max speed
Casterina
Line max speed
I'm on Unlimited Fibre Extra package and was wondering is this the max speed my line can get?
https://i.imgur.com/lhwBfql.jpg
https://i.imgur.com/0FUHix4.jpg
Fixes: 34
Re: Line max speed
Hi @Casterina
Unfortunately, I am unable to open and view the pictures from your links - for some reason our intranet does not like imgur, apologies for that.
However I can provide you with your estimated speeds range and current sync rate!
Our suppliers have stated that your Downstream Handback Threshold is between 35 - 48.9Mbps as seen here;
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 78.7 55.8 20 19 48.9 Available Available --
VDSL Range B (Impacted) 67.6 40 20 13.4 35 Available Available --
Despite this, I can see that your router is syncing at 57.2Mbps, so over and above that threshold.
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 57.2 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 448.9
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 06:30 to 20:15
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-04-24T13:45:00
I hope this helps.
Let us know if we can do anything else for you.
Kind Regards,
Alisdair
 MoR
Casterina
Re: Line max speed
Thanks for your reply @MasterOfReality, the two image links were the BT Wholesale checker and router stats.
As seen on your image, my speeds are within the low downstream line rate of 40-55.8Mbps, do you know how I can get to the higher band of 67.6-78.7Mbps? As the router shows the maximum data rate is 21942 up / 68293 down.
Also, my noise margin is 6.3 / 6.3 but I read online that BT has rolled out the changes to 3dB?
