Line max rate >100Mbps but synced at 79995k - possible to make use of headroom?
- Line max rate >100Mbps but synced at 79995k - poss...
28-03-2017 6:59 PM
Noticed that my router's showing a max line rate of ~123000Kbps but I'm training up at the PN max of 79995 - is it possible (or ever going to be possible) for those of us with the aforementioned blistering max rate to make use of the extra headroom?
Message 1 of 2
(580 Views)
1 REPLY 1
Re: Line max rate >100Mbps but synced at 79995k - possible to make use of headroom?
28-03-2017 8:58 PM
Guessing you are very close to the cabinet, however the current max product that BTW, and hence PN is 80 20.
Will they increase speeds, good question!
Message 2 of 2
(549 Views)
