Line fault fixed, still slow speeds
Rajveer86
I called a few days ago due to low speeds and stuttery latency (I was maxing out download at around 31Mb), and was told that there was a line fault. The Openreach engineer fixed the line yesterday, then ran a test from my master socket with his test device. The test device reported a SNR margin of 3.5dB, download speed of 74Mb and upload of 14Mb.
However when I run a speed test myself I'm still hitting around 31Mb download. Can somebody check if I am being affected by dlm? I tried calling support but the agent wasn't very helpful.
12 REPLIES 12
Rajveer86
Re: Line fault fixed, still slow speeds
Ok I called support again and we tested with the Plus One hub, the hub was syncing ~60Mb but still downloading at 30Mb. The agent then said he changed the profile and after a while I'm now downloading at ~55Mb. My HA612 says that I am syncing at 63Mb down and 15Mb up with an SNR margin of...21.9dB!! I think it's clear that I'm being affected by dlm so I'd like to request a dlm reset to see what happens please (since I did just have a line fix).
Mads
Fixes: 79
Hey @Rajveer86,
Thanks for getting back to us.
There is an underlying issue that is causing the SNR margin issue you are seeing your side. I have provided a further reply via ticket here. Please reply with your availability and we can pick it up from here.
Thanks.
Rajveer86
Awesome, I've replied, thank you for checking on this first thing in the morning Smiley
Mads
Fixes: 79
Great, all updated for you @Rajveer86 Smiley
Give us a nudge if there is anything else we can assist you with.
Thanks.
Rajveer86
Hi @Mads, the engineer has come and said that everything looks fine with the line. Immediately after I've connected and my ping has risen to 16ms and I'm now only hitting 45Mb download. Something weird is going on, can you take a look please? I was rock solid at 6-7 ping so I think dlm is kicking in, can I get a reset please.
RandallFlagg
Fixes: 75
Hi @Rajveer
I've reset your profile - let's see how this looks in 24 hours and take it from there.
Dave
pippin2019
Slow speeds especially from 4pm onwards. Phone line checked - all ok . So bad we cannot use two devices at once. Really disappointed as I thought fibre broadband would be much quicker then non fibre!
RandallFlagg
Fixes: 75
Hi @pippin2019
Thanks for getting in touch. I can see that you've raised this with my colleagues who have opened a fault ticket for you here.
Could you please let us know how you get on with the steps contained in that ticket and what the results of a speed test are via a wired device?
Best wishes
Dave
Rajveer86
Hi @RandallFlagg,
I've given it 24 hours and I've seen no improvement. I've tried disconnecting and reconnecting, reconnecting with the Plusnet router e.t.c. I'm syncing at 56Mb download and am only able to download at 45Mb, I have a ping of 15. This is worse than before the first engineer came to fix the line (when I actually had a line fault). What is going on?
HarryB
Fixes: 256
Hi @Rajveer86, looking over the account and testing the connection isn't flagging up any problems in regards to speeds.
While they are around what you're advising (Currently in sync around 49Mbps) the speeds we're seeing when testing are within the estimates for your connection:
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 49.5 Mbps
Upstream Speed 14.8 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 759.3
Upstream Rate Assessment Very Good
Technology VDSL
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 59.6 41.2 11.8 7.2 35 Available Available --
While I appreciate speeds may have been higher in the past, 15ms ping doesn't sound problematic and I'm afraid our suppliers are unlikely to accept a fault regarding slow speeds when the line is performing within the estimates unless there is another problem being exhibited.
 Harry Beesley
Rajveer86
Great, thanks for the help, I'll live with a slower speed and higher ping that what I used to have shall I...Tell me why is it that before a line fault I'm getting a better connection than after 2 engineers come to fix and check out my line?
You reply is basically saying screw you, we're not helping.
RandallFlagg
Fixes: 75
Hi @Rajveer86
I'm afraid the information that my colleague has provided is correct - line speeds (and as a byproduct, ping speeds) can vary and whilst I appreciate that this is frustrating when you've historically achieved a higher speed, our suppliers will not treat this as a fault whilst your speeds are within the estimate for your line.
Best wishes
Dave
Moderator's note by Mike (Mav): Tag fixed.
