Line fault? (Checked) or router fault (Changed)?! Sudden speed drops until reboot
fail
Hi, (cliffs at bottom)
I had my account activated around 6 weeks ago. After a week or so I noticed problems. I was away for a bit and when I came back I still had an issue. My line syncs at about 70mbps, and I get that speed when on ethernet or next to the router with my phone.
The problem is the speed was dropping dramatically, I mean to 0.2mbps down. However the upload was staying around 9mbps. When I rebooted the router everything was fine again, but this was happening 1-3x per day. There were also occasional total drops with not even a ping getting through.
After some back-and-forth with support where I initally said I thought there was a problem with my router they arranged for an openreach engineer to come. He tested everything and said it was solid and nothing he could find wrong. He also installed a dual-port phone box and then plusnet sent a new router. Incidentally on the days between plusnet arranging for an engineer to come and him coming only once I think did the speed drop to 0.2mbps. It did keep dropping, but down to 2mbps down. ALL the time the upload stayed around 9-10mbps.
It seemed somewhat solid for a day or 3. It is also possible it happened but I didn't notice due to a) not being there and b) the new issue is now it has dropped to 3-4mbps again so I might not have noticed. Still upload is around 8-9mbps (slower and doesn't seem to be as solid according to speedtest).
It just happened now, I rebooted and it was back to downloading at 70mbps.
Any ideas at all? Tearing my hair out here. Thanks!
tl;dr line drops to 0.2mbps, works again on modem reboot. engineer visits and also a new modem. now dropping to 3mbps approx and working after router reboot.
Fixes: 541
Re: Line fault? (Checked) or router fault (Changed)?! Sudden speed drops until reboot
Sorry to hear you're having speed issues. Testing your line isn't identifying any issues. your router is in sync at a downstream of 80mbps and upstream of 20mbps.
It sounds like you're having a problem with the WiFi when you're away from the router? Unless you're having speed issues via Ethernet too? If it's wireless related, have you tried changing the WiFi channel in the router settings?
More information can be found here: https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
Anoush
fail
it's only happened 2-3 times in the last few days as opposed to 2-3 times a day before the new router.
I'll go through your ethernet motions again when it does happen again
fail
It's been better than it was before the replacement router (not happening 2-3x per day)
However, tonight around 7 or 7.30 net dropped for a minute or two and came back.
Then around 9pm speed dropped again dramatically.
3mbps/9mbps again still the good upload
Then I went to plug in to ethernet to test for you and the net disconnected totally. Orange light.
Came back on itself and I achieved this great speed.
Then I did this speedtest (on ethernet)
0.65mbps/9.6 upload notice the good upload still
So reset router as is my standard operating procedure (a nice slow reboot it is to!), pretty certain speed would be back to what it should be:
Notice the upload stays constant throughout the fault.
Please advise
fail
Happened again 5 minutes after above post Sad
Fixes: 541
Can you run a BT speedtest for me please at http://speedtest.btwholesale.com using a wired connection.
Please ensure that no other devices are connected to the router (wired or wireless), and there are no open background tasks on the PC you're using.
Once you have the result, please complete the further diagnostics. This will store the result on the supplier system.
Let us know once you've done that.
Anoush.
fail
Sorry for the slow reply but I was abroad from 5th July. It seemed to be ok before I went away.
I returned a couple of days ago and have been having the same issue.
I attempted to perform the requested test. For the first bit I got this result
For the further diagnostics, I first got this error
And then after trying again shortly after this one
 There was someone here using the connection whilst I was away but only for very basic web and he didn't have any feedback on how the connection was and wouldn't probably notice
Please advise. Thanks
fail
I just tried again and I got through to the bit where it asked me to change my broadband login on the router (after the first part of "further diagnostics") which I did, but nothing much happened just got this screen.
By the way, they ask you to reboot your router before beginning the test, but I didn't, as we all know that this solves my problem (for a short while)
fail
Please help!
Moderator's note by Mike (Mav): All caps edited as per Forum rules.
Fixes: 541
Sorry to hear you're still having speed problems
Can you raise this to us at http://faults.plus.net?
ickam
@fail wrote:
Please help!
Hi, we have exact same issue, except our internet connection drops out completely.
@fail would you mind me asking if your problem has been resolved, and if so, how?
fail
It seemed to get a bit better for a while. And now it seems to currently be much more stable. I haven't had to reboot recently. There was no changes on my end at all, I wonder if they did something under the bonnet? I never re-opened the support ticket...
fail
Haha, of course I mentioned it and then today was the same problem!
Sod's law
fail
24 days router uptime  (so none of the above issue) now today was broken when I woke up, rebooted. And broken when I've got home from work. Grrrrrrr
