Line check
- Line check
Line check
Line check
31-08-2015 10:27 PM
EDIT: Just noticed there's some packet loss happening along with the changing speed so I've been sitting on 17070 quiet line for a while now but the line sounds no different than before when it was working fine
Also tried a gateway hop and now the speeds are higher, up in the 65-72 range while before the hop it went all the way down to 6Mbps. Regardless though, the speeds are still flakey at best and any http downloads are crawling speed. Is this just another PN related issue or something?
I thought it might be worth noting that my upload speed is still completely solid and clocks in at 18.73 consistently and doesn't fluctuate at all. Also there have been no resyncs, stats from 8800NL seem perfectly normal and only manual session drops to try and get on a different gateway.
SUPERFAST
Re: Line check
Re: Line check
31-08-2015 11:45 PM
Your BT IP profile is directly related to your sync speed. If your profile hasn't changed there will not have been an issue with the line.
Re: Line check
Re: Line check
01-09-2015 6:46 AM
Pretty odd, I've seen some other posts with some pretty bad packet loss from evening to midnight. Hope this isn't a normal thing from now on.
Re: Line check
Re: Line check
01-09-2015 9:53 AM
He knows the sync speed along with a lot more useful information as he uses a Billion 8800NL
Quote stats from 8800NL seem perfectly normal and only manual session drops to try and get on a different gateway.
@NoZephy
You are seeing this problem http://community.plus.net/forum/index.php/topic,140851.0.html
Re: Line check
Re: Line check
01-09-2015 9:58 AM
Re: Line check
Re: Line check
01-09-2015 10:05 AM
Re: Line check
Re: Line check
01-09-2015 10:30 AM
Quote from: Anotherone So why waste CRT's time asking for a full line checks for taps then
Because I've never had any sort of issues like this with the line thus far, and even though I can see the stats from my router on my end it would be nice to have some clarification from PN staff on the status of my line to narrow it down.
Also, I pay them quite a fair bit to get access to the internet, I'd like to think they have my back and would help me if I made a request.
Quote from: Oldjim @NoZephy
Maybe that is the problem but before I've only experienced speed loss on the single thread download, this time it was on the multi threaded download and I was getting packet loss all the way until midnight.
I've done another gateway hop this morning as the speed was a bit flakey but packet loss was gone and now the line is perfect again, no packet loss or speed loss.
Re: Line check
Re: Line check
01-09-2015 10:37 AM
Re: Line check
Re: Line check
01-09-2015 10:50 AM
I asked for help because I was unsure, sorry if I'm not an MLG pro and don't have greater knowledge on my ISP's network or BT's network etc. I just stated in my last post that before I've only experienced speed loss on single thread downloads, this time it was on multi threaded as well and I was getting some packet loss which is what threw me off and though it might be something between me and the exchange. I changed gateways over 5 times last night and it never fixed the issue like it has done before, there was always packet loss and the speeds were always fluctuating like crazy.
That's all there is to it. If a mod can lock the thread it would be greatly appreciated.
Re: Line check
Re: Line check
01-09-2015 10:59 AM
Edit: leave the thread open and CRT may pick this up later if they have time and test your line if you really want that assurance.
Re: Line check
Re: Line check
01-09-2015 11:07 AM
Nah there's no point in keeping it open, it's definitely an issue related to the capacity thread.
Re: Line check
Re: Line check
01-09-2015 11:10 AM
Thread locked at OPs request.
Customer and Forum Moderator.
