Line check
- Line check
Line check
21-06-2020 2:21 PM - edited 21-06-2020 2:22 PM
Can I get a line check please. I've been getting daily disconnects recently it seems (again), resulting in slow sync rate drop everyday.. just wondering if all is well?
Re: Line check
23-06-2020 1:09 PM
Thanks for getting in touch @santi I'm sorry for the issues you've had. I've tested your line today the tests aren't showing any issues with the broadband signal going into your router, that's getting a good speed of 58mbps and no drops for 2 days.
If you aren't seeing this speed, I'd recommend raising a speed fault online at faults.plus.net. It's worth noting that together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in speed faults being fixed.
Re: Line check
05-07-2020 1:46 PM - edited 05-07-2020 1:51 PM
But something is definitely not right.. once again my sync speeds dropped now to a shocking 47meg...
Something is definitely not right here.. as you can imagine this intermittent issue is very annoying, as probably by the time you go to check the line it'll stabilise.. and then flare up again after. My sync speeds were at a solid 70+, then dropped to 60, and now 47.. so something doesn't sound right
Connection type:Fibre Broadband (VDSL)
Downstream sync speed:47.28 Mbps
Upstream sync speed:11.90 Mbps
Network uptime:0 Days, 3 Hours 5 Minutes
Re: Line check
05-07-2020 1:52 PM - edited 05-07-2020 1:52 PM
