Line check please
- Line check please
Line check please
19-10-2015 1:13 PM
Could someone at plusnet check my fftc for any faults ,since my home phone line had problems on Friday which were sorted some time Saturday , my snr has gone from 15.1 to 6.4 and my attainable rate from 59,000 to 41,000 and I am now getting loads of fec errors which I was not getting before , I am synced at 40,000 2,000 with an snr of 6.4 which was 15.1 on Friday morning before the fault
Cheers
Chris
Cheers
Chris
Message 1 of 4
(674 Views)
3 REPLIES 3
Re: Line check please
19-10-2015 3:52 PM
No faults detected Lenny.
Your line is synced at 40/2 which is what I'd expect based on your line and the product you're on.
Message 2 of 4
(392 Views)
19-10-2015 4:46 PM
The FEC errors are probably down to interleaving being applied after the problems with the phone line (assuming it was not on prior) - if the line remains stable now then it should recover and DLM will remove the interleaving (usually takes between a few days and a week or so in my experience). Likewise with the snrm/attainable although since you are already syncing over your profile that is not so much of a problem.
Message 3 of 4
(392 Views)
19-10-2015 5:38 PM
Thanks for the replys , interleaving is on and also G.INP is on on the Downstream only, this was on before the problems friday , I was just wondering why the snr had dropped from 15.1 to 6.4
Message 4 of 4
(392 Views)
