Line Test Report
jphallows
Line Test Report
Morning all.
Are there any staff members about who could post the full GEA test results from my line please ?
Test was carried out under Question #202000383 but the case was closed minutes after basic down/upload results were posted, leaving no chance to respond.
Thanks in advance
4 REPLIES 4
MatthewWheeler
Fixes: 479
Re: Line Test Report
Thanks for your post @jphallows
I've provided this for you below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 53.7 Mbps
Upstream Speed 19.8 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 496.7
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Technology VDSL
DP Type External
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2020-05-25T10:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 53.5 Mbps 53.6 Mbps 53.6 Mbps
Up Stream Line Rate 19.6 Mbps 19.7 Mbps 19.7 Mbps
Up Time 820.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2020-06-07T09:57:21.495+01:00 2020-06-07T10:12:21.495+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Matthew Wheeler
jphallows
Thanks very much for that Matthew.
The 'Profile' on this information is definitely up to date at 0.128M - 80M Downstream ?
The BT Wholesale test I performed today was still showing the Downstream Profile to be limited to 50Mbps even though the Upstream has been increased to 20 Mbps :
Basic Performance Test -
Time Stamp
Latency
Download
Upload
Sunday 7 June 2020 | 15:41:34
24 Ms
45.46 Mbps
18.45 Mbps
Advanced Performance Test -
Download Test
Download speed achieved during the test was 45.46 Mbps
For your connection, the acceptable range of speeds is  40 - 49.51 Mbps
Your DSL Connection Rate: 0 Mbps(DOWN-STREAM),0 Mbps(UP-STREAM)
For your connection, the maximum achievable download speed is 49.51 Mbps
Profile for your line is 49.51 Mbps
Upload Test
Upload speed achieved during the test was 18.45 Mbps
For your connection, the maximum achievable upload speed is 20 Mbps
Profile for your line is 20 Mbps
Assuming I'm reading this correctly ?
I've never actually achieved over 50Mbps download (wired at the master socket). Just wanted to double check the line wasn't still 'limited' as current speed is right at the bottom of speed estimates for the line.
Many thanks
Terranova667
Fixes: 5
Your Profile in the GEA test is not up to date if you take a look at the date stamp for it you will see it's dated 25th May, the profile in a GEA test is never up to date it's always 1-2 weeks behind so do not go by that.
jphallows
Hi Terranova.
Thanks for the input. Yes I'd seen the date of the GEA.
I suppose the question should really be why todays BT Wholesale test is showing a profile of 50/20 (download/upload) when it should have changed from 50/10 to 80/20 on 13th May ?
